2 members (Scott35, ampherder), 230 guests, and 9 robots.
preben Offline OP
I am wiring a house with Dietrich TradeReady joists.The openings in the joists are 6x9 inches and the edges are rolled 90 degrees.The metal edge is very sharp and I feel that an insulator is necessary. Is there a special insulator available for these joists? Or is there another way to do it?
Sounds to me like this is not a place for NM. If you are using AC, MC or EMT there should be no problem with sharp edges.
-Hal
I don't have much experience with NM, or the joists you're talking about. If there are no special insulators available, maybe a piece of garden hose cut to length, slit lengthwise and slipped onto the sharp edge.
Dave
Always a good idea to talk with the AHJ also.
Dave
spelling!
[This message has been edited by Dave55 (edited 11-13-2004).]
Try Dietrich themselves!!
From their website:
"Be advised that both pipes and wires may need bushings or cable supports
They then refer you to Arlington Industries (yep, my favorite guys), for more
