We have a dual-locomotive that needs to be done now, but I don't think that I'll get to do it
GJ
I did end up doing this job last Friday. Cold weather is moving in and the customer was getting very nervous about cold starts.
We ended up setting a fused disco for each locomotive on the hand rail at the center point of the two locomotives. That way they can run either system independent of the other. The locomotives were connected tail-to-tail, the head end being the cab?????. There is a pump for hot water and one for the oiling system. Total load for both systems was 18A.
Thankfully, these units were very clean!
GJ
