526
20
Hi All! New member here. I work maintenance for a large church built in 1850. A lot of things we have around here have been here a long time, including these: They are used to stop people from switching off breakers that shouldn't be touched (ie. refrigerators, water heaters, etc.). Anyone know if and where these are still available? Thanks, Joe
St. Mary's Maintenance
I don't know about those items, stmarys, but you can get LOTOs that will keep people from turning off the switches.
Dave
Hi there Joe. Welcome to ECN!. I don't personally like the idea of fitting a device to a circuit breaker that prevents it from tripping, it sort of negates having the breaker in the first place. Mike :]
Mike, circuit breakers are required to be trip free. That means that even if the handle were locked, the internal mechanism would still operate. What it will do is prevent you from resetting the circuit breaker after it trips. - - - - - - - - - - - - - - - - - - - - - - - - - - - Charlie Eldridge, Indianapolis, Utility Power Guy
Charlie Eldridge, Indianapolis Utility Power Guy
Mike not to worry our breakers will trip even if you glue the handle.
All these do is keep people from turning off breakers that must stay on.
The one in the picture fits Square D breakers and is still available
How does one go about putting that on? and trumppy when a breaker trips it will trip even if the handle is held in place (I think) thants why you have to reingage the handle after it trips by pushing all the off and back on
Theres always enough room in the junction box.You just need a bigger hammer
Al Hildenbrand
Thanks a lot everyone! To address the question of whether the breakers will still trip with this clamp in place, yes. We've had them trip before. A special thanks to ElectricAL! I'm going to order a bunch tomorrow.
They are commonly found on Fire Alarm and similar loads in my area.
"question of whether the breakers will still trip with this clamp in place, yes. We've had them trip before."
Not that they will trip, but "trip free" (Very important!), not all breakers will trip free, meaning that the handle can be held closed and the breaker mechinism will still trip free of the handle. Not all breakers will.
