by NORCAL - 03/19/24 05:11 PM
1 members (Scott35), 274 guests, and 15 robots.
Page 3 of 3 1 2 3
#43558 10/19/04 10:20 PM
I don't think that anyone here would argue if we use a small piece of pipe to protect a piece of RX. However the big question is, When is the pipe too long? A 4' piece is OK? Then how about a 10' lentgh? Maybe 20 or 30 feet? When do we stop. I saw a job where someone ran 60-90 feet of PVC with a 12-3 RX inside of the pipe. Is that too much? What is the code section? Now if it goes underground, you can argue the RX in a wet location like ElectricAl stated. However how much pipe is too much? Maybe you could ask the AHJ?
Harold
#43559 10/19/04 10:21 PM
aldav53 Offline OP
I agree Russ. How can moisture get to it if you use compression fitting.
#43560 10/19/04 10:25 PM
aldav53 Offline OP
Good point Harold, I just can't see where the problem is with running NM in pipe if it is weatherproof.
#43561 10/19/04 11:21 PM
e57 Offline
I'm with you Attic Rat on this, as I can not even get THWN,it is not even stocked at our several supply houses! I use THHN in conduit outside all the time! (Listed for damp location.) Maybe something unenforced here? Not that I'm looking for it to be, I like stocking one type of wire.
Wait, I just checked, its all dual rated............. THHN/THWN/MTW, just says THHN in larger lettering. Duh.... Just when you thought you could break some rules.
[This message has been edited by e57 (edited 10-19-2004).]
#43562 10/19/04 11:24 PM
e57 Offline
Oh, most RT fitting only become RT as they cross into Canada. There is something I get away with!
Page 3 of 3 1 2 3
