1 members (Scott35), 565 guests, and 35 robots.
#43144 10/05/04 08:17 PM
having a brain fart here and this is my only source of information at this moment so anyway- how many watts = 1 amp or what would be the formula etc?
#43145 10/05/04 08:22 PM
P=IxE
P Watts
I Amps
E Volts
You need to know the volts, NJ
Dave
#43146 10/05/04 08:24 PM
e57 Offline
v/w=I Wait..... I almost farted too!
P/E=I
[This message has been edited by e57 (edited 10-05-2004).]
#43147 10/05/04 08:25 PM
for exp. on a 120 volt circuit
#43148 10/05/04 08:33 PM
Then it's 120 times the amps.
-Hal
#43149 10/05/04 08:36 PM
that does not make sence i am tring to find the amps? say for ex. i have 10 fixtures with 100 watt bulbs that total ='s 1,000 watts so if i need to know how many amps that draws i divide that by the voltage (120) therefor my answer would be 8.3 would this be correct?
#43150 10/05/04 08:55 PM
NJ Wireman, 8.3 amps is correct.
Roger
[This message has been edited by Roger (edited 10-05-2004).]
#43151 10/05/04 08:55 PM
thanks to all for the help
#43152 10/05/04 11:08 PM
< Begin Monty Python Mode >
And now, for something totally different...
< End Python Mode >
Just for fun, do the P=I×E thing with an AC load having 0.83334 Lagging Power Factor; however, the figure "P" will reflect the Apparent Power (Volt-Amps), as applied to NJ's True Power example:
...No need to do the calcs, I just felt a little cocky...
...must have one hand in one pocket!
(totally old and semi rude joke). [Linked Image]
Threw the VA thing in as a "semi-subtile" reminder of True Power vs. Apparent Power figures on AC systems.
I'll return you now to your regularly scheduled Program, already in progress.
Scott35
