mgd001 Offline OP
Hi, this is my first post, happy to be on this forum.
The main breaker for our 3-phase/460v building power tripped on Friday and the Emergency Generator and ATS switched on. I noticed that the Genset out put display showed this: 468 v ,60hz , 715 amps total.
but each seperate phase measured around 235amps. is this enough to trip the breaker due to overloading?
I thought that a breaker marked 700 amps could hold 700 amps per pole?
thanks to all.
I am a little confused with how many amps you are drawing, I have never seen a generator with a "Total Amps" meter.
If you have 235 amps per phase then we would say the breaker has a 235 amp load.
Each pole of a 700 amp breaker is rated 700 amps but we do not call it a 2100 amp breaker.
A typical 700 amp breaker should not be loaded to more than 80% (560 amps per leg) for periods exceeding 3 hours. That is unless you have a 100% rated breaker, most are not.
mgd001 Offline OP
The amps draw per leg was around 235 each. a=235amps, b=235amps, c=235amps
Thanks for the clarification.
Our Generator was installed a few weeks ago and it has a slick microprocessor display, with the Total amps reading.
This 700 amp breaker has a little switch assembly Called a "ground-censor" on the panel below the breaker that could be sensing a fault somewhere.
I'll post more details soon.
