I have a two part question regarding upgrading the existing 60 amp electrical service in my home. First, some background.
1. It is a 2 family home in Connecticut
2. Heat, hot water and ranges are all gas
3. it is being sold as a condition of the sale is upgrading the services to seperate 200 amp services.
First question is, considering that heat, hot water and ranges are all gas, would 100 amp services be sufficient for roughly 860 sq. ft apartments, considering that the new owner may install central air and an air compressor in the garage to do remodelling work?
Second, Is there a way to have a 200 amp service brought in and split at the meter can to provide seperate 200 amp services to each apartment or do I have to bring in a 400 amp service from the street and split it at the meters to provide the 200 amp services to each apartment?
Any help would be GREATLY appreciated since I need to get this done ASAP!!!!!
Thanks
Yes, Yes and NO.
Earl
So this means that YES, 100 amp services for each apartment would be enough, even for central air and an air compressor and YES, I can split a 200 amp feed at the meter (I'm assuming just wiring the meters in parallel???. I ask because I didn't know if that was legal to do)and NO, I don't need to try and bring a 400 amp service into the house from the street. is that right? Thanks
Yes
Earl
earlydean, you do ramble on sometimes, try to keep your answers short next time.
OK
Earl
