#41267 08/23/04 10:20 PM
BigB Offline OP
Has anyone seen a remodel can in a 9 inch square, IC rated model? I have a customer that specifically wants the square recessed lights, I can't talk them into round. They must be both remodel and IC rated. Any help will be appreciated.
Brian
#41268 08/23/04 10:35 PM
I have never seen any remodel type square recessed lights in IC or NON-IC. I think you are going to be out of luck here. All of the square IC housings I have seen are of the double wall design so there is no way they could be installed from below the ceiling.
Good luck!
Curt
Curt Swartz
#41269 08/23/04 10:40 PM
No but I can't see why the standard cans can't be used in a remodel. Cut the hole, screw some cleats on opposite sides of the hole inside the sheetrock, install the fixture and screw it to the cleats. Yes, you may have to patch the screw heads in the ceiling.
-Hal
Oops! Forget that, I forgot about the IC requirement.
[This message has been edited by hbiss (edited 08-23-2004).]
#41270 08/23/04 10:55 PM
LK Offline
Thank you for the trip back to the 50's , just about every finished basement, had square recess fixtures installed. Might find them in an antique shop.
#41271 08/23/04 11:16 PM
e57 Offline
Prepare to pay though the nose, and I personally hate this companies idea of quality 9for what you pay), but...
http://www.luciferlighting.com/d_fixtures.htm
#41272 08/24/04 06:25 AM
K
I seem to remember Lightolier having square downlights, and I believe they were available in a remodel configuration, since the job we needed them for was a partial remodel. They would be pretty stinking expensive, 4 cell parabolic louver I think.
Even a blind hog can find an acorn every now and then
#41273 08/24/04 10:28 AM
How about a round remodel can with a square trim. Elite makes one. I looked on the web site and can't find it, but I'm looking at it in a catalog right now. Here's the web site, you might call them. http://www.iuseelite.com
#41274 08/24/04 10:17 PM
BigB Offline OP
Thanks for all the help.
Eagle that was a good site. I sent away for their catalog.
