1 members (Scott35), 516 guests, and 17 robots.
#40400 07/18/04 08:24 PM
durant Offline OP
I do apt.maint.& was wondering if using a CAT-2 meter is enough,or do I need a CAT-3?
#40401 07/19/04 01:45 AM
What is a CAT-2 meter?
Edward
Thanks
Edward
#40402 07/19/04 07:04 AM
I am understanding you to be asking about the division or category in relation to the power supply category 2 being from the panel and toward the interior, cat 3 is for the area outside pole and meter socket fluke has a small diagram that breakes these areas down rather well. if you do maintainance and deal with a wide range of electrical ( hopefully all within your licensing and abilities)there are several nice selections would recommend (www.fluke.com) go to basic test or the digital meters under the products list
(dont know how to post a direct link or i would) can anyone explaine that please?
[This message has been edited by sparkystudent (edited 07-19-2004).]
#40403 07/19/04 08:42 AM
The rating you need on your meter essentially depends on how close to the service entrance you will be working. The category rating system is explained very well here:
http://www.fluke.com/download/library/1263690_w.pdf
(PDF reader required)
