#4020 09/06/01 10:36 PM
Redsy Offline OP
A customer wants "Hockey Puck" lights in a corner kitchen cabinet(glass door). Sorry, I never installed them. Anyone have any details before I go to mega-supply and view the wares? Low, line voltage? Cut hole? Mount inside?
Thanks!
#4021 09/06/01 11:01 PM
Redsy,
They're typically low voltage Halogen. They can be purchased individually or in 'kits' with LV Trans, wire and splice fittings. I always try to put a receptacle above the cabinet (if no soffit) and install a switch for it.
#4022 09/06/01 11:43 PM
If they can be hidden by a front lip on the shelf, or the customer doesn't mind seeing them, we use good quality double faced tape to stick them to the bottom of the shelf, or the bottom of the cabinet itself. Hiding the xfmr and making the line connections in a box have always been my headache.
The "pucks" we use (WAC brand) have about 30" leads on them, so we use them as branch wiring, and use those tiny tap connectors to tie them together
#4023 09/07/01 12:20 AM
What do you do when there is a soffit?
I have this very problem coming up but Redsy beat me to the thread!
[This message has been edited by sparky66wv (edited 09-07-2001).]
-Virgil
5 Star Inspections
Member IAEI
#4024 09/07/01 06:36 AM
an option many cabinet makers have is a 'light bar' that extends the bottom of the cab down to hide the pucks & wires.
usually i wire these under, or internal to the cabinet back to a switched X-former. I hate to bury any splice...and yes, the X-former placement is a bear
#4025 09/07/01 08:17 AM
Virgil,
If there's no soffit perhaps you could locate the outlet/transformer remotely somewhere. Or, how about in an adjacent Cabinet that has no glass? Would that be kosher?
#4026 09/10/01 07:45 PM
Turns out there's no soffit after all...
I've already roughed-in using the same method as Bill's... Glad I ain't gotta change it!
[This message has been edited by sparky66wv (edited 09-10-2001).]
-Virgil
5 Star Inspections
Member IAEI
#4027 09/12/01 10:20 PM
Just remember that the lights get hot! Consider this when looking at the trim, etc.
