by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
#40218 07/14/04 11:56 AM
I come across ground wires put together like this constantly.. I always at minimum use a crimp (I also placed a crimp here after the pic)
[Linked Image from pstr-g02.ygpweb.aol.com]
-Randy
#40219 07/14/04 12:17 PM
It doesn't look the wires in the pic were twisted too tightly. I can see between them. 110.14(B) says splices are to be made with devices identified for the use
#40220 07/14/04 01:22 PM
I'd add a reference to:
250.8 Connection of Grounding and Bonding Equipment.
Grounding conductors and bonding jumpers shall be connected by exothermic welding, listed pressure connectors, listed clamps, or other listed means.
Al Hildenbrand
#40221 07/14/04 04:11 PM
I think a lot of amateurs and professionals alike think "The ground wire doesn't ever do anything, so there is no need for a connector."
Around here, the crimp barrels are pretty popular, but they are often "crimped" incorrectly, that is, just flattened onto the twisted conductors with pliers making for a less than ideal connection.
Peter
Peter
#40222 07/16/04 07:13 AM
V
Not enough sheath in the box?
Where the ground is crimped must extend 6 inches out of the box
#40223 07/16/04 08:12 AM
That is: 6 inches of free conductor in the box, 3 inches outside the box. (300.14)
Earl
