#3978 09/02/01 11:54 AM
aldav53 Offline OP
Anyne remember on the old 2 wire systems, what they called the white wire with no 3rd wire ground? Neutral or ground?
#3979 09/02/01 12:11 PM
I'm figuring you're talking about branch circuits. It was neutral. Some called it common. I'm not old enough to have seen any DC.
I sure wish the NEC would call this a "veeblefetser" or something. It confuses the heck out of most of the help when you start talking grounded and grounding conductors.
(BTW veeblefetser is from 1960-MAD magazine)
[This message has been edited by electure (edited 09-02-2001).]
#3980 09/02/01 01:16 PM
In those days the wires were the same color. I saw one in warren, Ohio recently, two fuses on a porcilein block and a disconnect nearby. It was in the attic and attached to the roof and it was still well 'dressed in'even by todays standards it was a really neat looking job and was probably installed circa 1903, accordingly; the grounded system came into being around 1913. As far as your question I would think it would be a grounded conductor although then they fused both sides, so who knows?
