#39471 06/21/04 09:17 AM
cavo148 Offline OP
What are the permissible methods of wiring beneath attached backyard decks and fastening to the framing members? RNC, UF, etc.?
Thanks in advance,
Andy
#39472 06/21/04 10:09 AM
I much prefer EMT. If you use RNC keep in mind that you may need expansion couplings, a major reason I don't use it for outside above ground runs of more than a few feet. UF will need to be protected if any of it is accessable.
-Hal
