Edward Offline OP
Ca you guys help me find a wiring diagram for a grinding machine:
Wiring Diagram #: D-45433
It is a huge grinding machine with a 225Amp 3 phase breaker.
I need to hook this baby up.
Any help will be appreciated.
Edward
Thanks
Edward
Did you search the web?
One of the better ones-
Electricians do it without shorts.
Edward Offline OP
Yes. I have found one instruction booklet. It is $200.00.
I will or the client will get it if we can not find it anywhere else.
Edward
Thanks
Edward
Try e-mailing the company customer support folks direct, or call them and explain your situation - that you don't need the full service kit, just the wiring schematics.
Hey, it might be worth the call.. and a damn sight cheaper than $200 either way!
