by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
#38620 05/27/04 11:49 PM
I want to tap off an existing welder outlet,that is not used and feed a 20 a 2p breaker that will feed an A/C unit. Is it legal? The breaker will be in a small QO panel.
#38621 05/28/04 07:34 AM
If the conductors are sized properly and you use some type of switch/disco that will allow only one to be on at the same time, it is OK.
