565
35
I have a need to bend an offset in 2 1/2" rigid. Can anyone help me? If not do you know who might rent a bender? I called a bunch of the bigger tool rental places with no luck. Thanks Scott.
I am sure you can get a hydralic bender for around 90.00. Some of those discount offshore no brand tool houses. I have a fellow electricain friend bend an off set into a 2" emt conduit, but I am told they work much better for rigded pipe. http://www2.northerntool.com/product/605/ Just wanted to add a link for something that might work in a pinch. [This message has been edited by dougwells (edited 05-25-2004).]
I have always used a hydraulic bender for anything over 2", welded or solid drawn conduit, on occasions I have used the pipe fitters bending equipment , could you find a pipe fitter locally who could bend it for you or do you need a lot of bends?
Did you try CLS? Standard Electric?
I would imagine big companies like that would rent tools, but I could be wrong.
The only one I am sure of that rents benders is Graybar, but they are few and far between.
Peter
No go at CLS. I will try Graybar tomorrow.
I am fairly certain we go here when we need extra benders and pullers.
Pro Tools 132 Calvary St Waltham, MA 02453 (781) 899-0790
Another suggestion would be do you know anyone at a trade school.
Call granite city elec. supply in brighton. Speak with dave loud
Hey Bob thanks. Jackpot! Several greenlee benders for rent. Now how exactly do you use them?
Be careful on line… www.greenlee.textron.com is the real deal. !!![www.greenlee-textron] is a scuzzball imposter!!! www.greenlee.textron.com/support/index.html is their support site, in Rockford, IL. Tool operating manuals are likely available in PDF. You might be able to get one in advance to know what to expect. Best of luck to you. 1 800 435 0786 ∙ 24 hr Fax 1 800 451 2632 mailto: support@greenlee.textron.com If you’ve got room, 30° offsets are the easiest to lay out. Maybe Allow For a Little SCRAP. [This message has been edited by Bjarney (edited 05-27-2004).]
