In this area you will find hinged light poles in use on the interstate highways.
These poles are 125' to 150' steel poles, when it is time to bring them down you install a couple of hydraulic cylinders on the pole base and use a hydraulic pump to bring them down.
I have never done this but I did pull over and watch them do this.
