Curt...
One reason I pointed out to unplug/disconnect "everything"... I should've noted for both circuits though.... my bad!
Thanks for pointing that out!
Now that I'm thinking about it, You could probably just leave the power off & ohm out between the ground & neutral at a recepton the problem circuit with the power off to BOTH circuits in the 14/3 & see if theirs any continuity!....
-Randy
[This message has been edited by Lostazhell (edited 05-01-2004).]
