1 members (Scott35), 148 guests, and 11 robots.
#37382 04/27/04 02:14 AM
rizer Offline OP
I have been told the way to determine wether a motor is spinning clockwise or counter clockwise is to look at it from the back of the motor ( the opposite side of the output shaft). Is this correct?
I apologize i'm not in the correct section of this forum. I also noticed iI cannot delete it to put it in the "general discussion" section.
[This message has been edited by rizer (edited 04-27-2004).]
#37383 04/27/04 02:40 AM
Rizer, my experience is just the opposite. Look at the end of the shaft for direction(VFSE). If the motor is double shafted, look at the end with the leads(VFLE). Some manufacturers might use the opposite of this, but this is the only way I've seen them.
steve
Steve
#37384 04/27/04 06:37 PM
The motors I've ordered have been tagged cw or ccw on the shaft end. Its my experience that you look at the shaft from the shaft end to determine rotation. My experience is strickly fractional hp if that makes a difference?
#37385 04/27/04 07:18 PM
rotation is looking at the shaft end unless otherwie noted. I've never seen it otherwise noted.
#37386 04/27/04 07:22 PM
F
shaft end for electric motors otherwise noted or specal installaments.
btw most engines [ gas and diesel engines] are set up by looking at the flywheel arrangement [ most engine run ccw set up but few do run in cw so just like electric motor just watch out that all ]
merci , marc
#37387 04/27/04 09:44 PM
rizer Offline OP
thanks for the answer and i'm glad i asked. the superintendant and the general formen both said the exact opposite .but, i'd heard different.
#37388 04/27/04 11:05 PM
I believe NEMA Standard MG1 used to define rotation of small- and medium-sized motors and generators as “viewed [ODE] opposite the drive end” but MG1-2002(condensed) seems quiet on the matter. IIRC, NEMA standards never defined a particular rotation for a given phase sequence.
#37389 04/27/04 11:21 PM
...Rizer, if you're still "fuzzy" about this, call an electrical motor repair shop,..where they do rebuilding,rewinding,servicing, etc,..and ask one of the techs there... [Linked Image] [Linked Image]
Russ
#37390 04/28/04 05:00 AM
rizer Offline OP
thanks guys I think that about covers it! I appreciate it.
