#37200 04/22/04 11:26 PM
Is it a) legal to manufacture my own spyder box from UL components?
b) I was told they are around 500$, if that's so, then It'd be cool to make my own at a fraction of that and add it to my tool collection! It seems quite basic to manufacture one or two, basically copying an old dead spyderbox a general let me try and fix. It has a 50 amp twist recep male on one side, female on the other, think it's 6, 20 amp recepticles, and 2, 30 amp 240 volt recepticles. It'd be a fun project! Thanx! take care, Brian
If each part was designed and listed specifically for the application in which it is being used, I don't see a problem with it. But I would still be hesitant about using these boxes for anything beyond personal use, just because of the liability you would incur should anything ever go wrong.
My $0.02
-John
I agree with John entirely and I would add that by the time you buy the parts and figure in labor you will not beat $500 by enough to make the liability worth while.
Curious as to the material you would make the box itself out of?
Bob
