433
18
I have always used copper for my service entrance conductors. Lately I have been thinking about using Al. I wanted to ask what other guys use and why they prefer one or the other. Thanks, Brian (not a new member, just had to re-register)
[This message has been edited by BigB (edited 04-01-2004).]
Copper in, copper out (as far as we go).
Depends on the size. If I were pulling anything bigger than 350Kcmil, I would use aluminum for ease of installation.
Ryan Jackson, Salt Lake City
Posts: 7,382 Likes: 7
Bottom line is "what is the spec". EE/PE specs cu, then it's Cu. If spec is al, then that's it.
Our design/build jobs are cu, unless the client has a tight budget.
The above is for large services, anything else is cu.
With the market prices for a lot of metals heading for the roof, cu & al are up also. (Seen prices for metal studs lately) Conduit & steel poles are heading up also.
We have pulled long runs of 600Cu, 750al, & Ryan's theory of ease with al is on the money, but you do what you have to.
The few resi jobs that we do are pipe & cu for 200 amp service.
Whatever the customer is willing to pay for. Most single family dwelling services i do with aluminum and almost all commercial/industrial are installed with copper.
For my own service entrance, aluminum.
I usually use aluminum if it is underground service entrance. Then I use URD cable. If it is overhead then I go with copper where I can. Copper is must easier if limitations allow.
Around here, 99% are aluminum.
Peter
Will be using Aluminum for my 200A service. Copper only gets used around here if its spec'ed.
We use copper unless AL is spec'd. Have had to repair too many places that had AL service, feeders, and even branch wiring.
ed
AL for all resi applications. CU for all commercial industrial apps.
How about Transformers? I always use aluminum wound XFMRs. in all applications.
