Ryan I was curious about the change in derating here in MA and Don R hooked me up.
The table we use was the table from the NEC and you can still see it in Annex B Table B.310.11
The difference is we still consider load diversity and the NEC no longer does.
The remarking issue is more about "if you do not know what your doing keep your fingers out of electric boxes"
