1 members (gfretwell),
32
14
Got a job estimate for a 50a outdoor spa. The run is about 100 ft. I would pipe up out of the panel (outdoor panels here in AZ) down the side of the house to a disconnect, then probably run liguid-tite to the spa. If the spa has a GFI built in or on a cord will I need one in the panel too? I usually do a job like this for around $500 to $600. Wanted to do some price comparing, what would you charge? Thanks, Al D
lotta factors to consider aldav53. does the panel have room? is there an outside GFI in proximity? does the disco (and $120 GFI) come with the unit?
~S~
Haven't seen the panel yet, but assumming it does have room. The spa probably does have a GFI built into it. Can get a 50a GFI for the panel at HD for around $70 to $80. I will have to buy the disc, about $20. Will I need a GFI recept within so many feet of the spa? Guess I better check the code book.
Some factors I allways look at for Hut Tubs:
-Trenching needed -If it has a deck how difficult will it be -If the deck is being built will they work with me to leave a few boards loose or repair if I have to pull up a few boards. -If the a GFI disconect came with the tub (rare)or I supply -If something exsisting would cause a violation like exsisting Rec or lamps -I never end up doing any exposed outside surface mount piping but if they customer does not like my price I give them that option -The location of the disconect -The customer - If they can accept the fact they need a disconect on the deck or a pipe comming out of the house (I allways tell them what it will look like first) -The house is brick or wood -If the basement is finished -If the basement has drop cieling -Space to work around the panel -Space and size of panel -The panel grounding system -Type and cost of breaker needed -If it needs more costly materials like a lot of ridgid or compression -Weather (I charge more when the weather is extreme) -If I have to pay any fees for the job -Like you said length of run
I allways get the disconect that comes with the GFI breaker. That is how it is done around here and it is a little cheaper here that way too.
My prices run $850-$1250. Average run about 90'all in metal pipe except for a sealtite wip at the tub. My compediters prices are about the same to a bit cheaper. Once in a wile another company prices crazy cheep around $250. These are the ones that double tap the A/C disconect with 30' of seal tite across the yard. With the wrong breakers and wires. I would say my material is about $250. It allways takes 2 guys a day to do.
Every customer thinks it's like addind a receptical and should be about $100. Most think they are getting ripped off until it's done. Then they say they didn't realize the work needed.
The Disconect should be more than 5'and with-in sight (60'?).
