763
12
I thought this was kind of neat. Be careful of your answer for No. 13
BASIC ELECTRICAL EXAM
#1 What Color is the green grounding screw? __________________________ #2 When hooking up a 200 volt heater you must use 220 volt wire. True__________False____________ #3 Electricity will leak out of pipes if they are not connected with rain tight fittings. True__________False___________ #4 To trip a breaker you must stick your foot out as it walks by. True__________False_____________ #5 When dealing with conduit, the O.D. must exceed the I.D. or the hole will be on the outside. True__________False__________ #6 A keyless fixture cannot be unlocked. True__________False__________ #7 A circuit breaker reads “20” on the handle, This means it can only trip 20 times before it is worn out. True___________False__________ #8 If you plug something marked 110 volts into a 120 volt outlet, 10 volts will leak out and make a mess. True___________False_________ #9 The guage of wire tells you how many plugs you can hook into it. True_________False____________ #10 When pulling 4/0 wire into a ½” PVC conduit, the “PVC” stands for “Pipe very crowded”. True___________False___________ #11 An OHM is a Hindu Measurement of voltage. True___________False____________ #12 A flush mounted device may only be hooked up to a toilet. True___________False____________ #13 Electrical inspectors are also known as_________________________ #14 Service entrance conductors purchased from an electrical parts house with current already in are very dangerous to install. True___________False______________ #15 If you have a molded case breaker, the mold can be washed out with warm soapy water. True___________False____________
An AHJ with a sense of humor? Wow. (Unless, of course, it's the preview for the California State Exam)
The answer to thirteen, (forum correct of course) Ryan, Harold, John, Earl, etc... Roger
I first saw this bout ten years ago. My mom (also a #13) used to hand it out to electricians as a fun little joke. I was hoping some day I would see this exam again, its a lot of fun. Thaks for sharing it with us.
Ryan Jackson, Salt Lake City
..Thanx,I loved that..I made a copy to give to my guys...let's see how long it takes them to catch on....LOL!!! AR
