by NORCAL - 03/19/24 05:11 PM
1 members (gfretwell), 32 guests, and 14 robots.
#30921 11/02/03 11:06 PM
I'm trying to locate a burried wire. Its just some 12-2 uf wire. No trench tape, and my inductive amplifier is not strong enough.
Anyboady got a better method? I know there is another way but dont know how.
#30922 11/03/03 07:17 AM
This may sound a little crazy but I have seen it before with results so if anybody has any comments or experiences, let me know. We used to take two pieces of number twelve wire about a foot and a half long and bend a couple of inches on the end at ninety degrees. Then walk across the area you think it might be in and hold the wires in each hand loosely. When the wires moved in together towards each other then we dug straight down and there would be the pipe with the wires. Saw it a couple of times and it seemed to work. Something about magnetic fields? Try to stop laughing ok? Kinda on the same principle that people who search for the right spot to drill water wells. Kooky?
#30923 11/03/03 07:23 AM
If you have no luck "witching" for the wire, I would suggest seeing if you can rent a underground cable locater.
We have one and have good luck with it.
I have used it to find the far end of empty PVCs that had been installed during an earlier construction project but no one new where.
I pushed a 1/4" snake into the PVC and hooked the signal generator to that.
Worked great saved a lot of digging.
#30924 11/03/03 08:40 AM
I don't remember exactly how this worked, but another member previously mentioned this unorthodox method in a similar thread:
I have never done this, nor do I plan to ever do it
Disconnect a spark plug wire from the truck (w/ engine off [Linked Image]).
Run a jumper to the UG wire (be sure to disconnect all the other connections to the UG wiring)
Start truck, and walk along with an AM radio that's tuned off of any channels. The "ticking" will be picked up by the radio, and will be louder the closer you get to the UG wire.
#30925 11/03/03 10:08 AM
Gunther: I didn't want to be the first to post about "witching", but I've been there and done it...it works!
Ryan Jackson,
Salt Lake City
#30926 11/03/03 11:52 AM
Ryan,
But not everyone can make it work.
Don
#30927 11/03/03 02:08 PM
Very Very true! :-P
Ryan Jackson,
Salt Lake City
