#3068 08/04/01 09:00 PM
jmosmc Offline OP
hello, i am not an electrican, but iam trying to replace the flourescent fixtures in my aquarium with compact flourescents. i have decided to do it myself as opposed to spending $500.00 for a pre-manufactured fixture. the bulbs are 55 watt compacts. i hve asked a few hardware stores for help but they dont have much knowedge about compacts. what kind of ballast would i purchase?
james mcentire
#3069 08/04/01 11:16 PM
I personally think that there is no reason to replace your fluorescents with Compact Fluorescsents. You're in good shape with the U/L listed original unit, which is pretty efficient.
If you're doing this to save electricity, Thanks
Does the aquarium run on a GFI?
[This message has been edited by electure (edited 08-04-2001).]
#3070 08/07/01 05:42 PM
Anonymous
Unregistered
Compact fluorescents have a built in ballast.
Why change? Please see discussion elsewhere on cold cathode versus hot cathode.
These lights are probably on all the time. Hot cathode bulbs are more efficient.
#3071 08/07/01 07:32 PM
Compact fluorescents have built in ballasts?
#3072 08/07/01 09:55 PM
Anonymous
Unregistered
Are we talking about Edison base lamps? Yes, the ballast goes along with the base.
You do not wire in a separate ballast as with a long tube fixture.
#3073 08/08/01 07:36 AM
DSpark
Compact fluorescents do not have built in ballasts. The downlight above me has 2 reactor ballasts and 2 PL-13 lamps.
The 10 I hooked up yesterday had electronic 2 lamp ballasts.
The Edison base retros here at the house can be separated by simply unplugging the lamp from the ballast/base combination.
Your statement is totally false.
[This message has been edited by electure (edited 08-08-2001).]
#3074 08/08/01 04:45 PM
Anonymous
Unregistered
Some can, particularly the older models; some can't.
Can you provide a picture of a compact fluorescent which does not use an Edison base, that is, one for which you have to wire in the ballast?
#3075 08/08/01 07:31 PM
More than happy to oblige, but I don't know how to post it, so I'll have to send it to Bill. (BTW, I did find one @ home that doesn't come apart from the Edison base).
Here you go:
Shown are 2 compact fluorescent lamps, a Phillips PL-S13W/27, & a Sylvania CF13DD/E/835 Also 2 compact fluorescent downlight housings; one magnetic, the other electronic ballasted. One wall fixture with 2 compact fluorescent ballasts. A compact fluorescent lampholder with the wires that connect to the ballast.
[This message has been edited by Webmaster (edited 08-08-2001).]
#3076 08/10/01 11:40 PM
Honest! We use these all the time! These were in my garage
Thanks to Bill, we can communicate it without 1000 words.
#3077 08/10/01 11:48 PM
Anonymous
Unregistered
I thank you both. I've seen many variations of compacts (and circular) with Edison bases. This is the first I've seen compacts with wired ballasts. Are they hot cathode too?
