412
11
hello, i am not an electrican, but iam trying to replace the flourescent fixtures in my aquarium with compact flourescents. i have decided to do it myself as opposed to spending $500.00 for a pre-manufactured fixture. the bulbs are 55 watt compacts. i hve asked a few hardware stores for help but they dont have much knowedge about compacts. what kind of ballast would i purchase?
james mcentire
I personally think that there is no reason to replace your fluorescents with Compact Fluorescsents. You're in good shape with the U/L listed original unit, which is pretty efficient. If you're doing this to save electricity, Thanks Does the aquarium run on a GFI?
[This message has been edited by electure (edited 08-04-2001).]
Anonymous
Unregistered
Compact fluorescents have a built in ballast.
Why change? Please see discussion elsewhere on cold cathode versus hot cathode.
These lights are probably on all the time. Hot cathode bulbs are more efficient.
Compact fluorescents have built in ballasts?
Anonymous
Unregistered
Are we talking about Edison base lamps? Yes, the ballast goes along with the base. You do not wire in a separate ballast as with a long tube fixture.
DSpark Compact fluorescents do not have built in ballasts. The downlight above me has 2 reactor ballasts and 2 PL-13 lamps. The 10 I hooked up yesterday had electronic 2 lamp ballasts. The Edison base retros here at the house can be separated by simply unplugging the lamp from the ballast/base combination. Your statement is totally false.
[This message has been edited by electure (edited 08-08-2001).]
Anonymous
Unregistered
>The Edison base retros here at the house can be separated by simply unplugging the lamp from the ballast/base combination. Some can, particularly the older models; some can't.
Can you provide a picture of a compact fluorescent which does not use an Edison base, that is, one for which you have to wire in the ballast?
More than happy to oblige, but I don't know how to post it, so I'll have to send it to Bill. (BTW, I did find one @ home that doesn't come apart from the Edison base). Here you go: Shown are 2 compact fluorescent lamps, a Phillips PL-S13W/27, & a Sylvania CF13DD/E/835 Also 2 compact fluorescent downlight housings; one magnetic, the other electronic ballasted. One wall fixture with 2 compact fluorescent ballasts. A compact fluorescent lampholder with the wires that connect to the ballast. [This message has been edited by Webmaster (edited 08-08-2001).]
Honest! We use these all the time! These were in my garage Thanks to Bill, we can communicate it without 1000 words.
Anonymous
Unregistered
I thank you both. I've seen many variations of compacts (and circular) with Edison bases. This is the first I've seen compacts with wired ballasts. Are they hot cathode too?
