0 members (), 394 guests, and 18 robots.
#30308 10/15/03 07:22 PM
SvenNYC Offline OP
[Linked Image from kingfeatures.com]
Moose & Molly comic strip from October 1.
#30309 10/16/03 07:55 PM
LOL! Plugging electric irons into overhead lights used to be quite common in Britain years ago.
With some older homes having just a single 5A lighting circuit, I can imagine this scenario being far from rare! [Linked Image]
#30310 10/17/03 09:35 AM
Sven: How true!! Unfortunately, I see this all the time, mostly in lower income houses here in my area. The fixture in the middle of the ceiling is typically one of those porcelain keyless lampholders, with sometimes as many as two or three socket/plug adaptors screwed into it (in order to have the necessary number of plugs, of course) [Linked Image]. Then extension cords are run from it to all corners of the room to supply power to everything from televisions to irons to air conditioners.
In one home, I traced an extension cord from one room into another. When I asked why they didn't use the fixture in the ceiling of that room, I was told "Oh, that fixture burned out several weeks ago". Mind you, this is in a house with an elderly, bedridden family member, who wouldn't have a prayer of escaping alive in case of a fire [Linked Image].
[This message has been edited by mamills (edited 10-17-2003).]
#30311 10/17/03 03:52 PM
The original K&T wiring was for lights only, shortly afterwards some of the pullchain fixtures were changed to a switch/receptacle combo that mama plugged her newfangeled iron onto
many still exist here
