0 members (), 376 guests, and 7 robots.
#30103 10/04/03 10:59 PM
iwire Offline OP
This was brought to my attention on another forum and I would like to pass it along.
Basically the Ideal Vol-Con solenoid tester has burnt some people.
July 31, 2003
Release # 03-167 Company Phone Number: (877) 557-8598
CPSC Consumer Hotline: (800) 638-2772
CPSC Media Contact: (301) 504-7908
CPSC, Ideal Industries Inc. Announce Recall of Voltage Testers
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission announces the following recall in voluntary cooperation with the firm below. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of product: Ideal Solenoid Voltage Testers
Units: About 122,000
Manufacturer: Ideal Industries Inc., of Sycamore, Ill.
Hazard: These testers can short out at high voltages. Consumers can suffer burns.
Incidents/Injuries: Ideal has received 11 reports of these testers shorting out at higher voltages, resulting in the faceplate blowing off the units. Two users were burned when their units reportedly shorted out. One reportedly sustained third-degree burns on his hands, forearms, neck and face, while the other suffered second- and third-degree burns to his hands.
Description: These are Ideal voltage and voltage/continuity testers with model numbers 61-065, 61-066, 61-067, 61-076, 61-079, and 61-080. "IDEAL" and the model number are located on the front of the tester. The tester body is yellow. The wire leads have one black and one red test probe. Recalled units were manufactured between November 1999 and May 2002. Contact Ideal to determine if your electrical tester is included in this recall.
Sold at: Electrical distributors, industrial distributors and home centers nationwide between December 1999 and July 2003 for between $30 and $65.
Manufactured in: U.S.A. and Canada
Remedy: Contact Ideal to receive a free replacement tester.
Consumer Contact: Ideal toll-free at (877) 557-8598 between 7 a.m. and 5 p.m. CT Monday through Friday. Consumers also can access Ideal's Web site at www.idealindustries.com.
Media Contact: Glenn Hollister, of Ideal Industries Inc., (815) 895-1307 and Jim MacMurdo, of Ideal Industries Inc., (815) 899-7779.
#30104 10/04/03 11:07 PM
iwire Offline OP
Bill I see this info was already up in the safety and recall section(I missed it there) so if you want to pull it off of General discussion no problem.
Bob
#30105 10/04/03 11:25 PM
Bob,
It's always good to bring this kind of thing up to the top once in a while so more people will see it.
#30106 10/08/03 11:51 PM
Its a good thing it was posted here guys. I have one of these! Thanks! Matt
