#2983 07/31/01 10:26 PM
Anonymous
Unregistered
Can anyone note me an easy way to make-up a dead end three way and four way, or suggest a book that speaks laymans english.
#2984 08/01/01 12:14 AM
Do you mean a 3-way and 4-way switch set up as a switch loop (no neutral carry-through)?
-Virgil
5 Star Inspections
Member IAEI
#2985 08/01/01 05:33 AM
http://www.wfu.edu/~matthews/courses/p230/switches.html#
surf this a bit [Linked Image]
#2986 08/01/01 06:52 AM
Sparky,
Did you notice the fixture connections on the bottom drawing of the 4-ways?
#2987 08/01/01 10:11 PM
Anonymous
Unregistered
Originally posted by Redsy:
Sparky,
No I didn't notice the fixture connections on the bottom drawing.
Also, I'm speaking on sending the switch-leg on the Neutral. Actually, I got the information today, but thanks for your knowledge.
#2988 08/03/01 05:35 AM
Redsy,
what about em' ??
#2989 08/03/01 07:08 AM
Originally posted by sparky:
Redsy,
what about em' ??
Isn't the white taped wire going to the fixture is a violation of 200-7(c)(1)?
I would have made a transition at the light outlet to make the travelers white&red, thereby allowing black to connect to the fixture.
#2990 08/03/01 09:27 AM
Its actually 200-7c2, but you're abolutely right Redsy! I see this violation more on these internet drawings than I see it done correctly. This code requirement is ancient!
Matt
[This message has been edited by Matt M (edited 08-03-2001).]
#2991 08/03/01 09:51 AM
200-7(c)(2) it is.
Sorry!
#2992 08/03/01 03:59 PM
Redsy;
you got a sharp eye there!
