Should I phone my previous boss and tell him to cut up the splitter I made to plug in 8 radios for charging?
I took two 4x4 extension rings, bolted them back to back and mounted two duplex recepticles in each side, for a total of 8.
I put a 2' cord and plug on it.
Yes if there is anychance you will use this on a job that OSHA might stop at.
They see this in use and it will be a fine, not get rid of that.
You already spent more in stock then a couple of plug strips and throw in an OSHA fine and you boss will be an unhappy radio user.
