0 members (), 483 guests, and 9 robots.
#29785 09/24/03 09:17 PM
Does anyone know if anyone makes a tugger that is powered manually or a cordless drill through a gear reduction.
I thought something like this would be good for site lighting and branch circuits.
I am aware of the two small tuggers that are powered by right angle drills and a power threader but they both need power to operate.
#29786 09/25/03 05:12 AM
I thought about building one once. All you need is a reduction drive with a 'tugger' pulley on it. I never got around to doing the math on the ratio/torque versus size/weight/cost etc.
#29787 09/25/03 07:52 AM
Greenlee (used to at least) has a crank operated puller.
It looks so much like a fishing rod and conventional reel that I found it nearly impossible to use without daydreaming excessively, though...S [Linked Image]
#29788 09/25/03 01:54 PM
With the advent of high torque cordless drills, I'm sure one of the largest will mount instead of the usual Milwalkee type right angle drill on any of the pullers advertised. I found one advertised in EC & M made by MAXIS that shows a corded drill. There is one advertised in Electrical Contractor made by Express Tech. , that is 12 volt dc powered.
Rick Miell
[This message has been edited by rmiell (edited 09-25-2003).]
