1 members (Scott35), 413 guests, and 10 robots.
#29734 09/23/03 03:40 PM
sparky Offline OP
I just can't seem to find those temp light stringers made of SO cord around here
I'd much rather p[ay a few more bucks for those than the loose wire stringers that end up in knotted splices.....
thanks in advance
~S
#29735 09/23/03 04:34 PM
#29736 09/23/03 05:33 PM
sparky Offline OP
perfect Bjarney !
3 suppliers said 'duh' , and goggle was uncooperative
sometimes it's quicker to ask here [Linked Image]
#29737 09/23/03 07:45 PM
Hey Sparky:
For what it's worth, have you seen the MH work lites from RUUD Lighting.
400 watt, MH, hook, cord & plug & they are relatively inexpensive.
RUUD has a site....www.ruudlighting.com.
They sell direct to EC & are in Wisconsin
BTW, the "Code compliant" temp strings are readily avail at two supply houses here, Cooper & GE Supply.
#29738 09/23/03 08:07 PM
Sparky:
In no particular order, here are some supply houses in Vermont:
Isabelle
59 Bridge Street
South Barre, Vermont 05670
(802) 476-8787
Toll Free: 1 (800) 639-2609
http://www.granitecityelectric.com/hours.htm
http://www.gmes.com/
Newport Green Mountain Elect. Supply
802-334-7963
802-334-7966 F
Midstate Electric Supply Corporation
Airport Road, Montpelier, VT 05602
(802) 223-1900
(802) 229-1607
Twin State Electric Supply
Industrial Lane, Montpelier, VT 05602
(802) 223-2488
Clifford of Vermont
P.O. Box 51, Rt. 107, Bethel, VT 05032
Voice: 1-800-451-4381
FAX: 1-802-234-5006
http://www.jgtemple.com/location.html
J.G. TEMPLE ELECTRIC SUPPLY
14 MORSE ROAD
BENNINGTON, VT 05201
802 639-5512
81 WILLIAMS STREET
BRATTLEBORO, VT 05301
800 213-9186
YANKEE ELECTRIC
276 EAST ALLEN STREET
WINDOSKI, VT 05404
802 655-4433
GREEN MOUNTAIN ELECTRIC
HCT 61,
BOX 27G
NEWPORT, VT 05855
802 334-7963
GRAYBAR ELECTRIC
21 ALLEN ST
RUTLAND, VT 05701
802 775-2555
WESCO DIST
4 HARBOR VIEW RD
BURLINGTON, VT 05403
802 864-9885
WALSH ELECTRIC
30 CHAMPLIAN DR
COLCHESTER, VT 05446
802 655-7090
Rutland Walsh Electric Supply
802-775-3672
802-775-8056 F
CED RANDBURY ROAD
RUTLAND, VT 05701
802 775-2972
[This message has been edited by ThinkGood (edited 09-23-2003).]
#29739 09/23/03 09:47 PM
The "loose wire" stingers are a code violation and have been since '96 or '99
Don
#29740 09/23/03 10:14 PM
F
don ; this was in effect in 96 code cycle and it was enforced by majorty of area now and alot of place will not appect the open string tempory lumaires
merci , marc
#29741 09/23/03 10:17 PM
There are still some "in between" products available.
Better than the "loose wire" but not SO cord either.
One type is "zip cord" and another type reminds me of 300 ohm twin lead antenna cable.
Both are UL approved for job sites 14 AWG yellow twin conductor assemblies.
Bob
#29742 09/24/03 06:57 AM
sparky Offline OP
thanks fellas
Think Good~
listed are some of the 'duhs' i deal with, many suppliers can't seem to get along with a desription alone, they need a cat # such as --McGill cat # 2252-0018 (which i'll now ph in this a.m.)
Don~
i recall the change, i also recall another passage allowing for a 'flying splice' , possibly in the '02.
#29743 09/24/03 07:36 PM
AFC makes the approved stringers that Bob is talking about.
Peter
