Have used T-Strippers for the >20 years of Field work (Ideal's Yellow handle type for #18 to #10 - and newer includes #8, and the Red handle type for #24 to #18).
Also have seen others use Sidecutters, etc. without any damage to the Conductors - and with equal ease and speed.
To me, if the Installer is confortable with a given method and it does not cause damage to the Conductors, there's no reason for me to demand a change.
Now, if the Installer is knicking the Conductor using either stripping method (strippers or cutters), then we have a problem which must be rectified!
As to the DIY shows demonstrating stripping methods to the General Public via Sidecutters, that's really uncalled for!
It takes practice and a learned "feel" to strip wire - even using designed Strippers!
I feel the DIY shows should push more towards doing the best job possible, in order to pass on a more "pride full" installation idea to the DIY'ers, but that's probably a pipe dream!
My Wife watches some of the popular DIY shows, and the stuff I see and hear really makes me angry!
Have enough fuel to fire off many, many threads of the subject matter, just from the past week of being home and the DIY shows on in the background.
??? How did I twist this topic into a DIY show tirade???
Anyhow, I use T-Strippers, but if others use alternate tools for stripping small gauge Conductors (excluding skilsaws and routers
..), and they are getting good results, that's cool with me!
I have tried stripping with cutters, but it felt unnatural - plus took me for ever to ruin a piece of #12 Solid! - so I choose to use Strippers.
Like one of the members mentioned (I think it was Ryan_J), after the spring is taken out and thrown as far away as possible, then the hacksaw removes those two finger pinching clips which held the spring, the T-Strippers are very sweet!
Also have used the "Automatic" stripper (the strip and slide thingees). It was nice for some limited stuff - such as stripping for device terminations, but after much usage the stripper fell apart! That, and it weighed about 10 times as much as basic strippers, so it never caught on for me.
I see others using these with success, and that's good!
Scott35
P.S. Although I do not use Screwdrivers as Cold Chisles, I do have a certain "'Big Bertha" Klien straight blade screwdriver that has only turned 2 or 3 screws in it's lifetime! It works great for prying up Walkerduct J-Box covers, removing caps in Walkerduct, and similar stuff.
Oh, and I am a "Die-Hard Pretwister", which has resulted in a shiny Copper coating on the grip faces of my Linemans' pliers!
S.E.T.
