1 members (Scott35), 150 guests, and 11 robots.
Page 2 of 7 1 2 3 4 5 6 7
#29462 09/18/03 08:32 PM
F
If i'm doing machine build i use t-strippers because they do a better job for terminal strips and you have a 1000 plus termanations to make and only use a screwdiver and stripper once everything is mounted .For construction i use side cutters,needle nose or diagnal cutters.Strippers are a one use tool and either i lose them or can't find them fast enough.The trick is not to cut the insulation but to crease it and pull it apart.I never nic the wire that way.
[This message has been edited by frank (edited 09-18-2003).]
#29463 09/18/03 08:35 PM
Did I mention I also strip the romex jacket this way! [Linked Image]
#29464 09/18/03 08:41 PM
LK Offline
Frank,
That's the way to do it.
#29465 09/18/03 08:42 PM
F
Hey I have a new pair of after factory kleins with a #12 hole I made with a hot pice of BX a few years ago.Can't use them though cause I still get mad.
#29466 09/18/03 08:59 PM
Maybe I shouldn't speak since those of you who have been in the trade 25 years have been in the trade longer than I've been alive. I am a big fan of Ideal super-T strippers...after I throw the spring away and hacksaw off the part that the spring clips to. It used to drive me nuts watching the older people I worked with use linesman's to strip, but then again I never had to troubleshoot their work because they never had any problems.
Ryan Jackson,
Salt Lake City
#29467 09/18/03 10:02 PM
Sandro wrote:
The Yellow T strippers are for solid wire, and the Red T strippers are for stranded.
Correct. I have both (should have stated that in the beginning). Obviously the red one gets the most use because I deal with a lot of stranded wire. The yellow one gets pulled out every few months....at most. [Linked Image]
#29468 09/18/03 11:55 PM
U
Yellow T-strippers are a permanent fixture in my bib overalls. Its what I use on odd-jobs, or when I'm one of six guys splicing for a whole day.
I have used my lineman's for stripping, but its a freak occurence - usually if I've misplaced my T-strippers. Also see the foremen do it too... since they never have tools on them, and use whatever they can borrow. Classic case of do as I say, not as I do. [Linked Image]
#29469 09/19/03 06:11 AM
Like Sven, I work a lot on radio and electronic equipment, and use various types of wirestrippers. I have side and end-action strippers, and several pairs of the automatic types and use them as the mood takes me. Sometimes when trying to strip a wire in an awkwartd corner one typoe wins over another on ease of access.
When it comes to house wiring, I have to confess to using side cutters sometimes.
#29470 09/20/03 01:26 AM
I've always used side-cutters to strip wires.
Having said that, when I am working on a new switchboard with lots of wires, I normally use pliers to strip and twist the wires, saves time changing tools. [Linked Image]
#29471 09/20/03 02:00 AM
O
I use Channelock pliers for the lot, every now and then i might use my pair of Klien side cutters but not often.
A pair of Channelocks last me less than 6 months.
Craig
