1 members (Scott35), 521 guests, and 40 robots.
#29096 09/08/03 06:40 PM
sparky Offline OP
gems here?
hey, they look kinda [Linked Image]........
Features:
Provides 9 volt DC Output to Trigger Smoke Detector (Conventional or ADA Compliant)
Miniaturized for hard wire applications. Easy to Install
Receives Turn-On Commands over the Existing AC power Wiring
Works with all CEPCO Transmitters
The miniaturized feature
[This message has been edited by sparky (edited 09-08-2003).]
#29097 09/08/03 09:20 PM
Aren't interconnected detectors suppose to trigger, or be able to be triggered, from any of the detectors that are interconnected? This system allows the detectors that are connected with this module, to sound off from a signal coming from a remote location. If a detector with this module senses smoke and sounds off, will it trigger the other detectors? The web site calls the device a "Receiver Module". Is it is also a transmitter? The module takes up 3.6 cubic inches, watch for box fill.
Steve
#29098 09/08/03 09:42 PM
sparky Offline OP
the nieghbors garage door opener touching off the smokes would eventually gain the local fire chiefs scrutiny.....
