Well Thank You very much all of you...from all your posts I gather I will just have to get an electrician and have the house re-wired...I wish there was a way I could have the owner pay up for it, since I am just a student and the owner is really hard on the maintenaces...well anyways, so I guess the shorting out the ground and neutral is out, and I was just wondersing, if I get the GFCI...will it really solve the problem? I mean what I really want is just to have the UPS up and running, and at least have backup power if there is no electricity...so if installing the GFCI can do the trick and I can have the UPS runninng, I will be glad to use the GFCI rather than do the whole re-wiring. Though after looking at the way the GFCI works, I kinda am doubtful whether it will work, but I wouldn't know, so please help me again and tell me if using a GFCI will do the trick. IF not well then I guess I should be calling the electrician...
How much should such a job cost resonably?? I live in Mobile, Alabama, and the house is a three bedroomed house about 40ft by 20ft...
any ideas??
SSS
