1 members (gfretwell),
32
14
Mama does want to see 4 exhaust fan ducts on her new house, just one 'big one' well hidden.
Is there a mini-HVAC, or similar unit i can install in the cellar of a residence?
the idea is to pipe all down to it.....
Steve (aka clueless) sparky
I think Nutone makes an inline ductable(is that a word ) fan that one can hide in an attic(only place I've heard of them being used). Not sure if they are big enough for a whole house though as I've seen them on back to back bathrooms.
Sparky, I recently used a Broan remote fan that had 4 4" inlets and 1 6" outlet mounted in the crawlspace. I piped all 4 bathrooms into it. It seems to work well.
I think the model # is mp280,don't remember the cfms.
Russell
ok Russ, how did you switch it?
Sparky, I used an allen bradley contactor with a 24v coil, used 24v transformer,ran 16ga. thermostat wire to a single pole switch in each bath.
Thats the only way my feeble mind could figure out.
Russell
that doesn't sound so bad Russ, i might have to give it a go.....thanx!
Doesn't Nutone make a lot of equipment for central vacuum cleaner systems? I seem to recall seeing a catalog of such under that name.
They sure do Paul.
They will sell you a complete vac system,inlets,piping,fittings, the whole 9 yards.
Russell
