by HotLine1 - 04/23/24 02:17 PM
1 members (HotLine1), 210 guests, and 8 robots.
Pete366 Offline OP
Allied E-Z pull ½ in. wire puller [Linked Image from freenet.edmonton.ab.ca]
Brotherhood of the 9.3X62
Pete366,
Welcome to ECN!.
I thought it was a handle off of a hacksaw when I first saw it.
Sorry, can't really help you there.
My guess:
it's a wire feeder--you attach it to the end of the EMT run, and when you feed the fish tape through it comes out the bottom of the handle. The wires then follow the fish tape back in the pipe, making a smooth bend at the top of the handle.
With his thing, maybe you could get away with a one-man pull for small wire (if you set the wire spools up right and are lucky).
It could be improved with the addition of a bottle at the top of the handle, like the hopper on a drywall texture gun, that would drip pulling lube onto the wires as they make the bend & enter the pipe!
Cliff
Pete, "Allied" is the EMT manufacturer and "E-Z Pull" is the name they use for the coating process of the EMT.
Steve
Pete366 Offline OP
I ran across it on ebay and could not figure out what it was now I see they got the name of the emt.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2543460540&category=26216
Well I see there were no takers for this gizmo. Thank god. 10 bucks plus shiping for a broken hacksaw and 35 cents worth of emt. What a ripoff.
