1 members (Scott35), 234 guests, and 26 robots.
#26618 06/16/03 09:21 PM
When I touch one of my leds-from my meter reader-to the ground (bare), and one to the Neutral (white--residential). I'm getting a 120V reading. Does this mean I have a Hot Nue reverse on one of my recepticles? Any helpful hints on safe ways of using my meter reader is welcomed!
#26619 06/16/03 09:56 PM
#26620 06/17/03 04:10 AM
Does an appliance plugged into the receptacle work? If not, then it could be an open neutral and you are reading the hot-to-ground voltage via other appliances.
If an appliance connected to the outlet works, then it may well be reversed connections. Have you tried measuring from the hot terminal to ground?
#26621 06/17/03 05:15 PM
You are right Pauluk. Thanks! Thanks to all!
