#26409 06/11/03 07:07 AM
sparky Offline OP
hi guys,
i have a reqest to install electric floor heat in a 6 x 17 (very high end)bathroom and wish to ask as to what quality products are available.
what have you used?
all pro's con's appreciated
~Steve
Steve
The system floor heating the has pretty much taken over in my area is www.nuheat.com
You can get the mats in standard sizes or you can order custom sizes.
I normally let the G.C. or tile contractor purchase the floor heating systems. The reason for this is liability. If this heating system fails not only am I buying a new heating system but I also get to buy a very expensive floor. I just have my guys run a circuit to the thermostat and then run a 1/2" conduit from the thermostat box to the floor so the non heating leads can be run up after drywall. At trim out we set the thermostat.
Curt
Curt Swartz
sparky Offline OP
thanks caselec
i may ask if the tile guy's already on this.....
Ihave Nuheat in my bathroom and have installed it in several others. They offer a 25 year warranty. I would buy it myself so I can get the profit. From my experience customer service is great. For one job I sent in the layout and dimensions of the bath and they designed a system. There are others but this seems to be the easiest to deal with as it comes pretty musch assembled. Other types you get a spool of wire and clips and a pain in the behind.
sparky Offline OP
well i am big on tech support...
Hello all....I know I am a little slow with this thread, as I have been away for a while.
As an alternative, I have had excellent results using the EasyHeat systems. I even installed one in my own house.
www.easyheat.com
Bye for now.
