Redsy Offline OP
Was there a consensus on the suitability of stranded wire on screw terminals?
I never thought there was an issue, but it came up on a job the other day.
From UL Guide RTRT. "Terminals of the wire-binding screw, setscrew, or screw-actuated back wired clamping types are suitable for use with both solid and stranded building wires."
I really don't like stranded wire on the screw terminals, but UL says it is ok.
Don
[This message has been edited by resqcapt19 (edited 06-01-2003).]
Redsy Offline OP
Thank you, Don.
I've seen the use of crimp on spade lugs connecting terminal screws to stranded wire. The ones with insulation where the crimping action happens. I don't know what the code has to say about this.....
F
left handed twist
[This message has been edited by frank (edited 06-08-2003).]
