#25305 05/04/03 10:34 AM
Joe2 Offline OP
Hi guys,
I'm having a problem with 60-75w household lightbulbs not lasting but about 2 months in my house. I live near the beach but don't know if the salt enviroment adds to the problem. Line voltage reads 115v-117v on the average. I also experience 1 to 2 brown outs a month.
Any imput will be greatly appreciated.
Joe
#25306 05/04/03 11:21 AM
Cheaper bulbs=weaker filament.Also I make sure to buy bulbs with a 130v rating.Granted they are gonna burn out at different rates but have had good luck. Hope this helps.
#25307 05/06/03 05:10 PM
Vibration from stomping on the floor above or slamming doors can always accelerate a bulb's demise.
Also, is it true that an enclosed fixture shortens bulb life or is that only if the fixture is overlamped?
#25308 05/06/03 08:18 PM
Joe,
How close are you to the transformer on the power pole? The closer you are the higher the voltage might be. I have a transformer from the power company right outside my house and I get 125-130 volts AC and my bulbs don't last too long. As Elektrikguy said, you might need 130 volt AC bulbs. They will last longer.
#25309 05/11/03 07:50 PM
Joe2 Offline OP
I'm located right off the transformer so I think our houses experience the same problem.
Thanks for the 130v bulb idea. I'll try it out.
Thanks everyone for the replies.
Joe
