0 members (), 220 guests, and 12 robots.
rmiell Offline OP
Our electric power plant has numerous lube oil heaters, tanks that have strip heaters surrounding them to keep the oil at around 160 degrees. I lost a control on one. Replaced it with another one which had a shorter cap tube. (old = 10", new = 4"). Now unit will not heat up oil before sensor senses top limit. Use infrared heat gun to test temp at cap tube, (which is mounted in a small metal tube welded to outside of inner tank, right next to heating elements), and it showed around 230 degrees.
Q1: Does the length of the cap tube need to be as long as the one I took out?
Unit is Hoffman-Allen brand. I can find no info on that company. They were in Springfield, Ill. when this unit was made, and installed in our plant, circa 1940.
Q2: Anyone have any links to them?
You can email me for any more info you need to help me with this problem.
TIA.
Rick Miell rmiell@hotmail.com
Long shot — Does the new sensing bulb contact the bottom end of the well? There may be a remote chance of inadequate heat transfer if not.
Rick,
I reckon that the sensor is too close to the heater, just a thought.
Or you've got the wrong wattage element.
