I'm not sure what you're looking for, but this is a illegal threeway.
Tie the hot to a traveler terminal, the neutral to a traveler terminal, run the common to the light. Do the same at the other switch. Both commons from each switch go to the light, hot and neutral run between switchs and are tied to the traveler terminals only.
Russ
[This message has been edited by russ m (edited 03-25-2003).]
