471
11
When doing EMT work, which do you guys prefer and why?
Posts: 440 Likes: 3
The Electric Eagle has landed again. I like solid for making joints, and terminating on devices. I like stranded for pulling through conduit. If I had to choose between the two, I would use stranded. Many times specs call for solid. When I have the choice, I use stranded.
Stranded on an island, Doc
The Watt Doctor Altura Cogen Channelview, TX
I like solid because if you're working by yourself you can push it quite a distance through conduit from j-box to j-box without help. Russell
my choice is straned for long runs for short run it can be both solid or stranded depend on what i have to termated it .majorty of my work is straned but only one disavange is when i pull too fast it can kink up if i am not carefull other wise it is easier to bend it fast than solid and the cost for each one is not much only few cents diffrence between both . ( dont ask me why )
merci marc
14 Solid 12 Strandid
Solid is a bit cheaper.
12 solid does terminate faster. Maybe I should try 12 strandid in the pipes and solid pigtails.
Anyone ever try those wirenuts with the premade pigtails?
I think Active 1 should get the "Best of Both" award. If I had to do it every day I would pull stranded and pigtail solid
Solid, 14& 12, and sometimes #10.
SOLID only for me when have a choice, had to pull some controls in freezer had to be stranded pulling off 15 spools at a time to get to 90. GEO
Solid may be ok for residential, but for durability stranded is the only way to go. I won't allow solid in a manufacturing plant except perhaps BX for lighting in drop ceilings. Len
