0 members (), 331 guests, and 10 robots.
#22641 02/26/03 08:25 PM
Counterman at the supply house asked me if I glued PVC conduit when installing it under- ground. My answer was yes, to which he said two electrical contractors had just told him that you do not glue PVC conduit when installing it underground. Have I always just done it wrong or what?
#22642 02/26/03 08:36 PM
Keep on gluing. 2002 352.48
"all joints shall be made by approved method"
I would doubt that no glue is an approved method
#22643 02/26/03 08:47 PM
We glue our PVC. I would never think of not glueing. However, any conduit installed underground is going to get a lot of water inside, glued or not, due to condensation. This is why the NEC defines underground conduit as a wet location.
#22644 02/26/03 08:50 PM
the glue will help keep the water out of the conduit too....
#22645 02/26/03 09:03 PM
I think that those two contractors must of done a bit of glue sniffing in their day!LOL
#22646 02/26/03 11:07 PM
The best part about gluing is that you have some hope of getting the water out.
#22647 02/26/03 11:14 PM
Anonymous
Unregistered
Think about this; what if not glueing allows the condensation to drain out?
#22648 02/26/03 11:23 PM
I know of a guy that didn't glue the pipes in a duct bank that got concrete encased. They don't stay together very well in that scenario! [Linked Image]
#22649 02/26/03 11:25 PM
You "glue guys" probably cut threads in rigid too -- I just put them sticks together with rubber Fernco's... [Linked Image]
Len
#22650 02/26/03 11:53 PM
This will sound strange to you guys I know.Our outfit does plumbing also,we alwaysduct tape a can of cleaner/primer to a can of glue for running pvc drains/waterlines.I know there will be giggles about this, but I,out of habit use the cleaner for pvc conduit also.
