Thanks for the input all. I certainly dont
want to go boom! If you really think this wont fly (i dont want it flying into orbit for sure..)I wont do it. Let me give you a better idea of what it all looks like in theory. PIC BELOW.
First of all ...use. This will be to paint a car i've been restoring. I already used the tent one time...but it got too misty in there and i already cough just from opening the paint can...even with a respirator on...so i'd like to vent it as best i can...
and also bring some fresh air in. Construction is PVC pipe with 4mil plastic to enclose it. I'll also be shooting with an HVLP gun this time...so mist should be less
and the reducer will mainly in the paint on the car and not in the air as much as with a conventional gun...but vapors will still build up if the tent isnt vented.
The motor wont be in the air flow. The entire fan unit will be outside the tent.
The squirrel cages are split in the middle and pull air from both sides of the fan enclosures. (outside where the pickup will be for the tent) and from the motor sides which will be in fresh air outside the tent
so there will be air to dilute the vapors that are pulled out by the fan units. From what i can surmise....the only mist or fumes will be traveling into a carbon filter, through the pvc pipes and into the squirrel cages then out the fan units to be dispersed in the air.
The reason i thought it would be ok to use this motor/cage setup is bcus it had previously been in the wall unit which was in the garage. I was thinking that given the fact that people store gas cans,lawn mowers,cars...etc in their garage that the fan unit would've been designed to resist
igniting such fumes via the motor or cages.
YES it was inside the metal wall housing...but that was not airtight and hardly fume proof.
Everything appears to be made of stamped steel. Is static electricity a real concern
given the fact it was designed for use in an indoor garage environment as i described above?
Given the whole story now...and the fact that this will be an outdoor deal with the motor exposed to fresh air...what do you all think? I dont want you to tell me what you think i want to hear... I want the truth.
Is it still a no no...and should i just vent the tent as best as possible without any motors or fans?
Also....what do you all think about the box fan to either pull air out...or push it in? I believe it is a magnetic motor type with no brushes...but i'll check first to make sure.
I'm obviously a Wile E Coyote....Super Genius type...always trying to come up with new do it yourself ideas....BUT I DONT WANT TO BLOW UP LIKE HE DOES ALL THE TIME. ---
Let me know for sure what to do OR NOT
here and I'll heed the advice.
Thanks again.
