This is what you should see in the browser.
https://www.electrical-contractor.n...ic=002551.cgi&TopicSubject=60Hz+/-?? But instead this is what you see.
http://electrical-contr actor.net...|QUS||QUS| Notice the last part of it? (60Hz|PLS|/-|QUS||QUS||QUS|). This is because ubb is supplementing it's own code (i.e. Ubb Code Is On) by saving the post information in the database as "PLS" for the plus sign (+) and "QUS" for the question mark (?). Thus when it is pulled from the database and pushed to the browser, the UBB software is translating it ok for some but not for others.
I am using MSIE 6.0.2600.0000 with not service packs on a Windows 2000 Advanced server and this page open up blank for me also.
Funny how it only effects the title of a message and not the body or the original post title.
[This message has been edited by JGonier (edited 02-25-2003).]
I just discovered something interesting. When the page opens as a blank page. Hitting the refresh on your browser gives you a blank page again however, if you hit the go button (in I.E.) the reply page will then open up ok.
This has to be a UBB issue when pushing the link to the browser.
Found another problem. When the software pushes the link to the browser, it is pushing it as "http://electrical-contr actor.net/cgi-bin/postings.cgi?action=reply&forum=
General?????&number=1&topic=002551.cgi&TopicSubject=60Hz|PLS|/-|QUS||QUS||QUS|". Notice the bold section? This should say "
General+Discussion+Area" instead.
