0 members (), 227 guests, and 13 robots.
#22550 02/24/03 10:37 PM
Anonymous
Unregistered
Can some one tell me if code requires you to phase-out neus--if you plan to dead in a three way? Please submit code article. I was told you do not have to phase the white (neu) black. HUN!!!!!?
#22551 02/24/03 11:25 PM
F
if you are planning use the white wire for looping (3 way switch ) the code do perment as long YOU mark the nueural wire diffrent colour to indentify the conducter. it will show up in nec about conducter colour codes.
the only colour i will not change is green that is ground conducter. i am sure few other will argree with me with this one
merci marc
( sorry for spelling )
#22552 02/24/03 11:40 PM
99 NEC 200-7(c)(1)(2)
Steve
#22553 02/25/03 05:31 PM
You can re-identify wire IN CABLE ASSEMBLY only, not single wires pulled thru conduit!
White wire re-identified (as black, red etc.) can supply line voltage to the switch, never use it as switch to light connection.
Andre
#22554 02/25/03 06:35 PM
Of course. That would make sense. In conduit you should have fished the correctly coloured wires in the first place.
